failover
gre tunnel
Enables periodic pinging of the primary gateway to assess its availability. When enabled, the system continues pinging, an unreachable gateway, for a specified number of times and at the specified interval.
This option is disabled by default.
Syntax
failover interval <1-250> retry <1-10>
Parameters
failover interval <1-250> retry <1-10> Specifies the interval, in seconds, between two successive pings to the primary gateway. If the primary gateway is unreachable, the system pings it at intervals specified here.
  • <1-250> – Specify a value from 1 - 250 seconds.
    • retry – Specifies the maximum number attempts made to ping the primary gateway before the session is terminated.
      • <1-10> – Specify a value from 1 - 10.
rfs4000-229D58(config-device 00-23-68-22-9D-58-gre-tunnel-testGRETunnel)#failover interval 200 retry 5
rfs4000-229D58(config-device 00-23-68-22-9D-58-gre-tunnel-testGRETunnel)#show context
 gre tunnel testGRETunnel
  dscp 20
Related Commands
no Removes the GRE tunnel settings based on the parameters passed
